Shift locking
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Shift locking
    Junior Member
    Sep 2004
    Shawano, WI
    181
    218
    1 times
    Shift locking
    My 98 can be put in gear without apply the brake like most cars these day. It has done this since I bought it so it either never had it or it broke before I bought it. It kinda scares me because I have remote start and a boy that's growing up really fast. I usually don't let him near the truck unsupervised, but I just want to be safe rather than sorry in the evident something would happen. Was this a standard item on 98s or something that can be added. If it's standard, where should I start looking for the culprit piece or pieces. TIA
    1998 Dodge Durango 4X4 SLT
    Sep 2004
    Anaheim, ca
    5,544
    77
    152 times
    My 99 is the same way, but the ram has the "step on the barke" safety lock, It's not broken, just was never engineered in the early gen 1's.
    2015 Dart Aero turbo1.4t, GFB DV+ BOV
    Durango Jedi Neil's Avatar
    Jun 2004
    Marlton, NJ
    2,251
    21
    2 times
    The brake lock federal mandate applied to passenger vehicles. The Durango was based off a truck platform which the regulation didn't apply to.
    Super Moderator tomk's Avatar
    Jun 2004
    Amherst, MA
    10,785
    16
    969 times
    your ignition switch should be off with no key, so the column lock will keep the shift lever from moving, no?
    Be amazed at the friends
    You have here on your trip
    07 JGC Red Rock Limited 5.7L
    And some past Durangos
    de W1PF
    Junior Member
    Sep 2004
    Shawano, WI
    181
    218
    1 times
    Quote Originally Posted by tomk
    Nope. I have used the remote start and as long as you don't hit the brake you can use the gear selector. Once you hit the brake it'll kill the engine unless the key is in.
  7. #6
    Sep 2004
    Anaheim, ca
    5,544
    77
    152 times
    Something is wrong with the steering wheel interlock.
  8. #7
    Junior Member
    Sep 2004
    Shawano, WI
    181
    218
    1 times
    Quote Originally Posted by dizzyD
    I never thought to try it it without the truck remote started. I'll try it once when the truck isn't started and see what the outcome is once.
  9. #8
    Jun 2004
    Amherst, MA
    10,785
    16
    969 times
    your ignition lock is toast.
    de W1PF
  10. #9
    Durango Jedi Master
    Jun 2004
    Fontana, CA
    7,519
    12
    202 times
    Did you modify the steering column in any way when the remote start was added? If not, I agree with previous post about ignition switch. There's an interlock between the switch and the gear shift. When you turn the switch towards the run and start position a pin is released that allows the gearshift to move, when in original stock configuration. This can be broken off, often when stolen.
  11. #10
    Junior Member
    Sep 2004
    Shawano, WI
    181
    218
    1 times
    Quote Originally Posted by MWeed
    I did had the remote start professionally installed.
  1. Hatch Not Locking
    By jjohn87 in forum Durango Discussions 1998-03
    Last Post: 05-13-2009, 01:28 PM
  2. Brakes locking up in a.m.
    By basicinstinct911 in forum Durango Discussions 1998-03
    Last Post: 04-25-2009, 01:38 PM
  3. Question re. locking gas billet
    By greg in forum Durango Accessories 1998-03
    Last Post: 04-16-2007, 07:46 PM
  4. Locking rear dif.
    By butch1581 in forum Durango Accessories 1998-03
    Last Post: 11-17-2005, 05:33 PM
  5. Auburn Locking Rear
    By skitzo.d in forum Durango Discussions 1998-03
    Last Post: 06-24-2005, 12:29 PM
Search tags for this page
2003 dodge durango gere shift lever wont lock
2003 durango shift lock
2003 shift lock solenoid durango
durango shift lever locking
my gear shift on my 1998 dodge durango is loose
