Front Driveshaft removed?
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Front Driveshaft removed?
    Grasshopper Hair-son's Avatar
    Sep 2006
    Vancouver, Canada
    96
    1245
    Just thought I'd throw a post in here for those with AWD. I know there have been a lot of posts about removing the front driveshaft from guys with fulltime 4WD, but couldn't find any with AWD?
    Heard clicking sound coming from under D?at low speed, high speed, straight and corners. I thought it was a CV joint, but when I got under the D, I noticed metal on the front driveshaft joint had been torn.
    On the AWD, the front of the front driveshaft is a 4 bolt u-joint, but where it connects up to the transfer case is a 6-bolt (or is it 8?) unit mounted on to a bearing assembly. Once all bolts front and back were off, a little prying and hammering and the driveshaft came loose. One of my bearings had torn free (probably from lack of grease since the boot that holds the grease in the bearing assembly was torn) and the bearing ricocheted inside the assembly, severely damaging the metal housing, and cracking the flange inside as well.
    The bearing assembly and driveshaft are all one unit, so I have to replace the whole thing?haven't got a price yet. If by any chance the length is the same, I might put in the driveshaft of a 4WD D, which I believe has u-joints at both ends. That would make servicing much easier in the future. I'll post some pics of the broken unit in a few days.
    -Harrison
    2001 4.7L AWD - 3.92 Limited Slip - Flowmaster 50 SUV - Chrome Intakes air intake + K&N Cone filter
    Durango Jedi Neil's Avatar
    Jun 2004
    Marlton, NJ
    2,251
    21
    2 times
    R/T Mark who had several long posts on his experiment with taking off his drive shaft was AWD (That's the only way R/T's are) I don't believe there has been any confirmation that any of the drive shafts have a different configuration. I have read that the drive shaft may be difficult and may require beating and banging.
    Durango Guru Don Fox's Avatar
    Sep 2004
    Oxford, Ohio
    1,230
    100
    44 times
    Harrison, if you can, take some pics of that joint and either post them or send them to me.
    When I made the part time to full time swap, there were no issues with the front driveshaft. Everything bolted back togther fine.
    Sep 2006
    Vancouver, Canada
    96
    1245
    Sorry about the wait Don - here are the pics. In the first photo, you can see what damage the bearing did to the inside of the casing when it broke loose! Both the hole and the bubble were caused by it I'd guess. If you look at the second picture, you can see at about 11 o' clock on the assembly where the metal ring that holds the bearings in place has completely broken off. Yikes! There was a rubber boot that surrounded the front of the assembly - it was torn and I cut it off to get a better look inside.
    Don - when you swapped to full-time 4WD, did you use this type of shaft?
    -Harrison
    Attached Thumbnails Attached Thumbnails Front Driveshaft removed?-pic3_354.jpg   Front Driveshaft removed?-pic2_814.jpg   Front Driveshaft removed?-pic_1_122.jpg
    Junior Member 85burbanator's Avatar
    Oct 2006
    170
    1264
    mine looks nothing like that on the R/T. its got U-jionts at both ends.
    2000 Durango R/T 4x4
    Stock till she's paid off.
    fun,free,addicting game- http://4x4country.net/register.php?REF=6565
  7. #6
    Sep 2004
    Oxford, Ohio
    1,230
    100
    44 times
    Wow Harrison, that's a rusty looking joint. It looks to me like they attempted to put a CV joint on there instead of a U-joint.
    Mu guess is that when the boot tore, the grease worked its way out via centrifical force which caused the joint to self destruct. I'm pretty sure that's what my driveshaft looks like as well.
    I'll try to take a pic or two in the next day or so and compare it.
    Give Mark Rose auto parts in Michigan a try. That's where I got my NV244 so I know he has front shaft for it.
  8. #7
    Sep 2006
    Vancouver, Canada
    96
    1245
    Hey Don, I read your thread on swapping to an NV244 transfer case, and I just wanted to confirm with you that your AWD truck is still using the same front driveshaft as when you had 4WD? And what's on the rear end of the shaft, a u-joint similar to the front?
    Wondering if any other AWD owners might be able to let me know whether their front driveshaft has two u-joints, or if anyone has a configuration like the one on in the picture?
    Thanks!
  9. #8
    Sep 2004
    Oxford, Ohio
    1,230
    100
    44 times
    Hairson:
    Sorry for the delay on the pics. Weather here in Ohio has been crazy for the last two weeks.
    Anyway, I'm indeed using the same two driveshafts that came installed with my part time NV 233 case. I'll go out here in a bit and crawl under and get a visual on the front shaft. I'll take some pics and hopefully can post them for you.
  10. #9
    Junior Member
    Jan 2007
    Canada
    196
    1352
    Hair-son;
    I checked under my D and my front shaft is the same as yours. U-joints on the front and flange attachment at the rear.
    Canuck "D"
    01 SLT+ 4.7 AWD 4X4 Fully Loaded
    It might take a bit of work but you can definitely fit a square peg into a round hole!
  11. #10
    Sep 2004
    Oxford, Ohio
    1,230
    100
    44 times
    Hair-son:
    Took a look under the D today while replacing the fog lights which had both finally given their all and were cracked and leaking.
    My front shaft looks like yours (and Canucks).
    BTW, did you ever give Morris Rose Auto Parts a call on your front shaft?
    The may still have the one that came with the NV244 they sold me. I think Corey quoted me $125 for the shaft when I asked him in case I ended up needing it. The 01 donor D only had 34k on it.
    1-800-345-0123
  1. Removed front air dam for improved off-roading
    By Big Cypress in forum Durango Accessories 2004-09
    Last Post: 09-01-2014, 05:55 AM
  2. Front driveshaft CV joint replacement
    By Connman in forum Durango Discussions 1998-03
    Last Post: 12-04-2010, 04:54 PM
  3. Front Driveshaft question
    By Hair-son in forum Durango Discussions 1998-03
    Last Post: 02-17-2007, 09:26 AM
  4. Has anyone removed their Infinity amp?
    By Grease is the Word in forum Durango Discussions 1998-03
    Last Post: 02-12-2007, 03:24 PM
  5. Well I pulled my front driveshaft today.
    By RT Mark in forum Durango Discussions 1998-03
    Last Post: 04-29-2006, 07:35 AM
Search tags for this page
2005 dodge durango front drive shaft removal
2011 durango front driveline removal
can you remove the front drive shaft on a 2001 d0dge durango
how to remove front drive shaft on 2004 dodge durango
removing drive shaft 2003 dodge durango
