won't shift into overdrive
Results 1 to 9 of 9
Thread: won't shift into overdrive
    Senior Member
    Jan 2006
    Schaumburg, IL.
    329
    1000
    Today it was -13 about -30 with the windchill and the D wouldn't shift into overdrive , actually the remote start had a problem starting it too. Any ideas? I changed the transmission oil about 6k miles ago, adjusted the bands and everything.
    Sold: 2000 Durango SLT+ 5.9L 4wd 100k Miles
    Sold: 2001 Durango R/T 5.9L AWD 55K Miles
    New: 2001 Mustang GT 4.6L
    KB2.1L (on the way) + bolt ons
    Durango Guru Don Fox's Avatar
    Sep 2004
    Oxford, Ohio
    1,257
    100
    51 times
    Adde:
    How long of a drive were you making?
    Our D's along with may newer cars today won't allow a shift into overdrive until the tranny temp reaches a certain level.
    My 95 SHO was the same way. If you made a short trip say, 4-5 miles or less it probably wasn't warm enough.
    Senior Member
    Jan 2006
    Schaumburg, IL.
    329
    1000
    you're right wasn't more then a 4-5mile trip but it has never had a problem before, I'm driving to work after this class so we'll see how it goes.
    Durango Jedi Silver Ghost's Avatar
    May 2004
    Upstate NY
    2,057
    5
    5 times
    Tranny temp needs to be above 50F before it'll go into OD. If you don't have far to go, this is most likely what happened.
    It should happen long before your engine warms up, but on a cold day like you're seeing, I wouldn't worry about it.
    Joe
    Joe
    Super Moderator tomk's Avatar
    Jun 2004
    Amherst, MA
    10,935
    16
    1015 times
    This morning my '03 4.7L wouldn't shift into OD until I'd driven about 10 miles? I suspect in this case, because I get on the highway pretty quickly after starting out, the radiator was staying very cold until the thermostat opened and this was overcooling the tranny fluid?
    IIRC the 46RE will refuse to shift into OD when the tranny fluid is below 50F?
    What?
    07 JGC Red Rock Limited 5.7L
    And some past Durangos
    de W1PF
  7. #6
    Grasshopper SvynD's Avatar
    Oct 2004
    PA
    52
    307
    I wouldn't worry about it yet if you're in the deep freeze region. It was -4 this morning here and I drove about 7 miles to work and I didn't get into OD either. Heck with the 180 degree t-stat I was shocked to actually have some heat this morning by the time I got to work! Usually it takes me about 4 miles for OD to lock in when its 32-15 degrees. My truck sits outside and I give it about 30 seconds before it hits drive.
    99' D, 5.9, 3.92, Modified IP III, FM TB, MPPCM, Custom Cat-back, MS Valve Body
  8. #7
    Junior Member
    Jan 2007
    Canada
    196
    1352
    I usually warm up the tranny a bit by putting it into D for about a minute before I go. It makes a difference on those cold days.
    01 SLT+ 4.7 AWD 4X4 Fully Loaded
    It might take a bit of work but you can definitely fit a square peg into a round hole!
  9. #8
    Durango Guru TheDodgeGuy's Avatar
    Jan 2006
    Oshkosh, WI
    1,295
    981
    Mine was so cold this morning that it actually went into "limp home" mode (only reverse and 3rd gears)! It also threw two DTCs?P0700 which is a flag code telling you there's a code in the TCM, and once the TCM was scanned, a P0841 which is a Low/Reverse pressure solenoid malfunction.
    It may have been my own fault?This morning I was running late, and hopped in the ice cold D (it was -18? today) backed up, shifted to drive, and it didn't move right away. I blipped the throttle and it engaged 1st gear, then almost immediately slammed into 3rd. I shut it off, and restarted it, and it then had all forward gears, but had the MIL on. I scanned it when I got to work and reset the codes, and it hasn't happened since.
    But back on topic, I don't get 4th gear until I drive a few miles, and even longer before the torque convertor clutch engages. This is normal operation, and nothing to be concerned about.
    Mike
    2001 Durango SLT 4.7
    Patriot Blue
    Mostly stock
    *SOLD*
    Currently driving a 2004 Jeep Grand Cherokee Laredo 4.0L and lovin' it!
  10. #9
    Durango Expert DelDurango's Avatar
    Oct 2004
    Thornton, CO
    777
    321
    5 times
    99 Chilil Pepper Red Durango, tan leather interior
    Mopar Performance intake, PPH Headers/custom exhaust, Superchips, MSD coil, helixed TB spacer
    Friday morning when it was between -13 & -21 6-6:20a.m. on my drive to work, my D didn't shift into OD the whole way there. and that's about 30 miles!! when I left for home around 3 p.m. or so, temps were higher and my D shifted into OD normally.
    Dan - retired military, got my AA from Front Range Community College, Westminster, CO. Now at CU Boulder
    99 D 4x4 5.9 / 4 spd a/t, CPR, leather interior, MSD #8228 coil, homemade CAI,Superchips 3715, (PPH headers/full custom dual exhaust, helixed TB spacer, Mopar M1 intake to come).
    97 JGC Limited 5.2/4 spd a/t, f/t 4wd, red, leather interior, mods to come
    04 Yamaha V Star 1100
  1. No overdrive-Help!
    By bjrobejsek in forum Durango Discussions 1998-03
    Last Post: 09-08-2012, 04:33 PM
  2. Dead Overdrive!
    By Hootman in forum Durango Discussions 1998-03
    Last Post: 11-14-2011, 08:09 AM
  3. Overdrive switch housing on shift lever is cracked.
    By twinrider1 in forum Durango Discussions 1998-03
    Last Post: 09-23-2010, 12:41 PM
  4. Overdrive Shuts off??
    By steltz in forum Durango Discussions 1998-03
    Last Post: 08-05-2006, 04:17 PM
  5. Overdrive help
    By Durango5.9L in forum Durango Discussions 1998-03
    Last Post: 10-10-2005, 05:07 PM
Search tags for this page
2001 dodge durango wont go into overdrive
2001 dodge durango wont shift into overdrive
durango not going into overdrive
durango overdrive doesntturn on
why is my 98 dodge durango wont go into overdrive
