No start problem??
Results 1 to 10 of 10
Thread: No start problem??
    Grasshopper 98Rango's Avatar
    Dec 2006
    Nova Scotia, Canada
    30
    1315
    No start problem??
    I drove my 98 Durango to work, shut it off and left it for 2 days. Came out tonight and it turned over like crazy but it wouldn't start. I can hear the fuel pump cycle but no start. Crank Sensor maybe??
    Everett Smith
    Durango Expert Big Al's Avatar
    Sep 2004
    Durham NC
    896
    74
    3 times
    1998 5.2, 4x4, SLT
    Is it even trying to fire up or just nothing at all??
    If it tries to start but then dies, or sputters but won't start, it could be a bad battery (many here have had starting issues where the starter turns the engine over just fine but it won't start or fires up a bit and then dies once you let up on the gas.)
    If it's not even trying to fire up, that sounds just like what happened to me when my crank sensor went out so it just might be that.
    Dec 2006
    18
    1328
    I had a similar problem. Turns out the connectors on my battery were extremely dirty. Cleaned them off and tightened them down and had no more problems.
    Dudu
    1999 5.2L, Superchips, Magnaflow, K&N FIPK Gen2 intake
    More to come.
    Aug 2005
    Antarctica
    15,068
    807
    101 times
    Possibly the crank position sensor or the fuel relay in the fuse box under the hood. The relays are interchangable so swap it with another one that matches and give it another try. It could be a bad relay you're hearing click when trying to start.
    Since it turns over normally, I'd say it's not the battery (until you kill it by repeated tries.) Also since it doesn't fire and then die, I'd still say it's not the battery.
    Keep us posted on the results.
    IndyD
    Durango Jedi Master
    Jun 2004
    Fontana, CA
    7,490
    12
    193 times
    Bad coil?
  7. #6
    Aug 2005
    Antarctica
    15,068
    807
    101 times
    Quote Originally Posted by MWeed
    Bad coil?
    Yep, from the description certainly also a possibility? I missed that one!
    IndyD
  8. #7
    May 2004
    ICE COLD NORTH JOISEY
    27,935
    7
    1747 times
    2013 R/T D HEMI
    I'm going with that as well or a bad distributor cap and rotor.
    Pull the cap off and look inside to make sure the rotor is intact and it's not all corroded in there.
  9. #8
    Dec 2006
    Nova Scotia, Canada
    30
    1315
    No start problem??
    Thanks, I'm gonna have a look at all the suggestions. Crank sensors are about $180 so before I get one I better make sure. I'll post the cure when I figure it out.
    Everett Smith
  10. #9
    Durango Guru WarrensD's Avatar
    Aug 2006
    Sint Maarten
    1,167
    1218
    1 times
    I wouldn't rule out the battery so soon.
    Warren's D
    2000 5.9
    M1/TB/B&G/JBA/CAI/Moore/drop/K2/Az/Bilstein/Hotchkis.
    Miller's Law #6: "Diplomacy is the fine art of saying 'nice doggy' repeatedly, while backing up & looking for a BIG rock."
  11. #10
    Dec 2006
    Nova Scotia, Canada
    30
    1315
    No start problem??
    After some cursing and a day to cool down I went back with a tow truck and to my surprise the Durango Started. This rules out the Crank sensor. Took it for a drive and parked it home. Next day it wouldn't go again. I did notice it had been wet lately so I pulled the cap and looked insideit was fine. Later on that day it went so I soaked the cap with water and it died instantly. Bought new cap and rotor and wires. Here's what I found? 2 corroded posts on the cap.
    Everett Smith
  1. Remote Start problem
    By JWhirl06 in forum Durango Accessories 1998-03
    Last Post: 10-09-2009, 08:12 AM
  2. Well its a start
    By Duranged408 in forum Durango Accessories 1998-03
    Last Post: 05-11-2008, 11:54 AM
  3. D won't start
    By sick chick in forum Durango Discussions 1998-03
    Last Post: 11-29-2006, 12:28 PM
  4. Another No Start Problem Solved.
    By Dman98 in forum Durango Discussions 1998-03
    Last Post: 08-17-2006, 02:23 PM
  5. 99 D won' start
    By doans99 in forum Durango Discussions 1998-03
    Last Post: 07-28-2005, 05:29 PM
Search tags for this page
1998 dodge durango no fire
1998 dodge durango no start and no fire
dodge durango no start problem
dodge forums no start issues
