Right Turn Signal Stays ON
Results 1 to 3 of 3
Thread: Right Turn Signal Stays ON
    Feb 2006
    1
    1016
    Hoping someone can shed some light on this problem for me. I have an 02 SLT and the when the lights are on, the right turn signal on the dash stays lit. After about 5 min, a chime goes off and doesn't stop. The only way to stop it's to shut off the lights. When I turn the lights back on, same thing happens. The turn signal lights up and after a few minutes, the chime starts again. I checked the fuses and bulbs and found no problems. Any suggestions? Thanks!
    Durango Jedi Master
    Jun 2004
    Fontana, CA
    7,543
    12
    210 times
    Turn Signals
    Sounds like a bad switch, if the switch handle is centered. Although you could possibly have a bad bulb.
    Super Moderator tomk's Avatar
    Jun 2004
    Amherst, MA
    10,867
    16
    992 times
    I'd check your turn signal bulbs? you might have one with the two filaments shorted together.
    Be amazed at the friends
    You have here on your trip
    07 JGC Red Rock Limited 5.7L
    And some past Durangos
    de W1PF
  1. Turn Signal Issue
    Last Post: 08-14-2011, 12:32 AM
  2. Driver Turn Signal
    Last Post: 07-13-2010, 05:01 PM
  3. Turn signal problem
    By IndyDurango in forum Durango Discussions 1998-03
    Last Post: 06-03-2010, 05:31 AM
  4. Right Turn Signal
    By Machine in forum Durango Discussions 1998-03
    Last Post: 07-19-2008, 11:24 PM
  5. turn signal problem
    By ShelbyStyle98 in forum Durango Discussions 1998-03
    Last Post: 03-09-2005, 11:42 PM
Search tags for this page
05 durango turn signal stays on
1998 dodge durango turn signal problem
1998 dodge grand caravan right turn signal stays on
turn signal light durango stays on
