differential gear ratios
Results 1 to 5 of 5
Thread: differential gear ratios
    Nov 2013
    1
    3121
    I bought a 99 dodge with a blown up front differential I called dodge and got my gears they said 355 but now I'm driving it and all the tires are. Chirping I looked at other old diff and said it had 384 gear which I didn't know dodge even had if you know anything let me know
    Durango Jedi Master
    Jun 2004
    Fontana, CA
    7,490
    12
    193 times
    In 99 the options were 3.55 and 3.92. To be real sure, take off the rear cover and read what the gear says. DO NOT GO INTO 4X4 OF ANY SORT WITH MISMATCHED GEARING.
    Super Moderator tomk's Avatar
    Jun 2004
    Amherst, MA
    10,672
    16
    930 times
    the window stickers were screwed up on the axle ratios for some '99s (like mine), but a vin lookup at a dealer should have gotten you the right parts.
    As mike said, 3.55 and 3.92 are the only possibilities.
    You *might* be able to go to the owners section of dodge.com and get a buildsheet for your VIN. I don't know if they go that far back.
    ...tom
    Be amazed at the friends
    You have here on your trip
    07 JGC Red Rock Limited 5.7L
    And some past Durangos
    de W1PF
    Administrator skitzo.d's Avatar
    Jul 2004
    Northern GA
    5,596
    46
    119 times
    2015 Ram 2500 4x4 Crew Cab and '42 Dodge Dually
    The easiest way around this until you get a gear swap is to drop the front drive shaft. I ran for 2 years with 2 different gears. eventually I swapped out the rear and added the shaft back in.
    It doesn't seem to me that it should make a difference as long as you are in 2WD. they didn't make an AWD in '99 as far as I know.
    Durango Jedi Master
    Jun 2004
    Fontana, CA
    7,490
    12
    193 times
    There is a full-time 4x option on some transfer cases for the 99. Going into that could tear up the transfer case or lock it so that it won't shift back out without jacking up the front axle to relieve tension on the driveline.
  1. Differential oil change help
    By Josh in forum Durango Discussions 2011-13
    Last Post: 10-22-2013, 11:13 AM
  2. Front Differential?
    By sermonator in forum Durango Discussions 1998-03
    Last Post: 08-04-2006, 05:14 PM
  3. Front Differential
    By mickeyd in forum Durango Discussions 1998-03
    Last Post: 06-16-2006, 11:49 PM
  4. Break-in period for a differential gear swap?
    By JohnKoz in forum Durango Discussions 1998-03
    Last Post: 07-15-2005, 02:04 PM
  5. Differential Cover
    By DurangoDude in forum Durango Accessories 1998-03
    Last Post: 06-20-2005, 07:31 PM
Search tags for this page
2015 durango axel ratio
99 dodge durango diff gearing
differential ratios 1999 dodge durango
dodge durango differential ratios
where does a ratio gaer go on a 2013 durango
