Fan Clutch Recommendation
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By Don Fox
Thread: Fan Clutch Recommendation
    Dec 2010
    20
    1964
    I recently put in a NAPA fan clutch and, while it does its job, its fully engaged for 3-4 miles every time I start it and the fan roar is too loud to hear anything else. I talked to NAPA and they said that's normal, all aftermarket clutches do that, and they wouldn't take it back. I suspect it may be a severe duty (i.e. police/taxi) unit so I'm going to get another one online (rockauto, autopartswarehouse) but I don't want to go thru this again. Can anyone point to a particular model or manufacturer that works well? I'd rather not pay dealer prices.
    Also, I've heard the V10 fan is quieter. Does that equate to less airflow? If not, does someone know the part number?
    Bill
    Durango Jedi Master
    Jun 2004
    Fontana, CA
    7,519
    12
    202 times
    No, the V-10 clutch and fan blades are designed to work at different speeds than the stock units. They're also what the factory suggested as a fix for the fan roar problem that was a "major" complaint on the 98/99 Ds. The V-10 blades are pitched at a different angle than the stock unit.
    Grasshopper Iwa2008's Avatar
    Feb 2008
    Honolulu, HI
    30
    1688
    I had the same problem. The only way to solve this problem was to get one from a dealer.
    2002 SLT Durango, 4.7
    105500 Miles..
    Dec 2010
    20
    1964
    How much was it?
    Durango Jedi Master
    Jun 2004
    Fontana, CA
    7,519
    12
    202 times
    If you check in the performance question area of the forum you should find the part numbers for the fan, clutch and shroud assembly used by the TSB Dodge put out for this problem.
  7. #6
    Durango Guru Don Fox's Avatar
    Sep 2004
    Oxford, Ohio
    1,207
    100
    40 times
    Bill,
    I've had great service from factorymoparparts.com down in Florida. They hooked me up with a brand new HD fan clutch for my 04 to the tune of $80 shipped to my door so you might give them a try.
    FireEater likes this.
  8. #7
    Senior Member thomsonc's Avatar
    Mar 2007
    Hawaii, USA
    311
    1426
    5 times
    2001 Dodge Durango R/T
    I put a Mopar heavy duty one in mine and it's indeed loud. I can't imagine aftermarket heavy duties being even louder. If so, I can understand why you want to swap it out.
    2001 Dodge Durango, R/T
  9. #8
    Sep 2004
    Oxford, Ohio
    1,207
    100
    40 times
    My new OEM clutch does roar a bit for the first half a mile or so, but quiets down quickly after that. In my book, if I can put OEM back in for close to or less than aftermarket, I'll do that unless the OEM product is known for poor quality. I had heard that folks were complaining of excessive noise with aftermarket units, hence the OEM choice.
  10. #9
    Durango Expert
    Oct 2005
    Central Florida
    843
    856
    How hard is it to do this yourself? Old exchanged and maybe time to go to the junkyards, that is if not stripped out already.
    2002 Dodge Durango SXT 4X2 4.7L
    JGC 545RFE TCM Conversion, 68mm FM TB, Drop-in K&N
  11. #10
    Sep 2004
    Oxford, Ohio
    1,207
    100
    40 times
    Qwassy,
    Changing the fan clutch is a fairly easy job. If you look here under my Gen 2 cooling system service post, I explain how to do it and also detail how to make a home brewed tool to hold the water pump still while removing the fan assembly.
  1. Need a recommendation for shocks
    By Tino in forum Durango Discussions 1998-03
    Last Post: 01-17-2009, 09:09 PM
  2. air intake recommendation please
    By Clif_diver in forum Durango Accessories 1998-03
    Last Post: 11-02-2005, 07:35 PM
  3. To Clutch Fan or not to Clutch Fan that is the question!
    By FSTDANGO3 in forum Durango Accessories 1998-03
    Last Post: 10-09-2005, 01:31 PM
  4. DIY header recommendation
    By fingers588 in forum Durango Accessories 1998-03
    Last Post: 08-04-2005, 12:56 PM
  5. Shock recommendation?
    By 99DurangoDavid in forum Durango Discussions 1998-03
    Last Post: 10-21-2004, 09:24 AM
Search tags for this page
2004 dodge durango loud fan clutch
2006 dodge durango loud fan clutch
dodge durango fan clutch noise
loud fan clutch durango
new clutch fan on 04 durango sounds loud
