Vibration after rotor change
Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: Vibration after rotor change
    Junior Member remembermysins's Avatar
    Apr 2009
    219
    1795
    2 times
    Hi all, got a question for you. I had my front brakes and rotors changed about a week ago and, yesterday when I took the old Dingo out on the freeway, I noticed a vibration at around 70 mph. Both the car itself and the steering wheel where vibrating, I felt the steering wheel vibrating and my passengers said they felt the vibrations in their seats (before you ask, no, they weren't "good vibrations.")
    I don't feel any vibration when braking, only at cruising speed on the freeway.
    Could something have happened when they were changing my rotors? I never noticed any vibration before having the rotors changed.
    Thank you. Daniel.
    2003 R/T
    Senior Member RennGent's Avatar
    Jun 2011
    Frederick, MD
    457
    2023
    18 times
    2003 SXT Durango 4.7L
    Always a good idea to make sure all your lug nuts are tight. It's quick to check by hand and then verify with a torque wrench later if needed.
    ~Nate
    4.7L, Fastman TB, Airaid CAI, Superchips 91 tune, Borla cat back exhaust, 180 T-stat, 1" drop, Bilstein shocks, Hellwig rear sway, Mag-Hytec trans & rear diff covers, Energy Suspension Polyurethane Bushings.
    4.7 Performance Options. www.fireflycoachworks.com
    Apr 2009
    219
    1795
    2 times
    That was my first thought and the lug nuts are tight (checked by hand.) I even thought they might have knocked one of the wheel balance weights off, but they all seem to be there, the outsides ones anyway.
    2003 R/T
    Durango Jedi Master
    Jun 2004
    Fontana, CA
    7,594
    12
    232 times
    Check for a broken belt or a blister in one of the tires, all 4 tires not just the front ones.
    Senior Member
    Sep 2004
    455
    72
    58 times
    I may have my vibration issues crossed up, but I seem to remember something about the front hub/spindle bearings not being interchangeable between sides and causing vibration if switched?? If the shop pulled the bearings during the rotor replacement, they may have gotten them crossed between sides.
    Of course, I may be way off base here as well? not enough coffee yet!
    2015 SXT Plus, Billet silver
  7. #6
    Durango Expert
    Nov 2006
    Stockton, California
    998
    1289
    18 times
    '05 Durango SLT Fleet 4.7.
    K&N Air filter, Westin step bars.
    Any other symptoms? or just the vibration?
  8. #7
    Apr 2009
    219
    1795
    2 times
    No other symptoms, just vibration. I inspected my tires though and noticed this on the rear driver's side wheel. Not sure if it's the reason for the vibration, but it can't be normal, right?!?
    <img src=http://i749.photobucket.com/albums/xx133/debauch72/09adceb6.jpg height=640>
    2003 R/T
  9. #8
    Administrator skitzo.d's Avatar
    Jul 2004
    Northern GA
    5,605
    46
    121 times
    2015 Ram 2500 4x4 Crew Cab and '42 Dodge Dually
    OH SNAP! I'd remove the tire and replace it with the spare and run it around the block. While you're out, get another tire.
  10. #9
    Aug 2011
    Northwest FL
    23
    2041
    Could be one of a few things.
    1. The calipers are hit and miss with these Durangos so you may need to clean it up. When you had it off, it may have knocked some dust/dirt loose that's causing it to stick a little. I had this issue with my previous 04.
    2. It's possible one of the rotors or pads may be bad or out of spec. Cheap pads can cause this too.
    3. May be as simple as needing to flush the brake lines of air, a small bubble may be close to the end of the line.
    Since the vibration is only at highway speeds and only when braking, that tends to point to a brake issue. However, that rear tire does need to be replaced SOON!
    04 Durango ST 4.7L 125K miles - traded in for:
    04 Durango Limited 5.7L Hemi 35K miles (as of Mar 2012)
  11. #10
    Durango Jedi Master
    Jun 2004
    Fontana, CA
    7,594
    12
    232 times
    That tread has a broken belt in it. Get it off the road ASAP for your own safety.
  1. Driveline vibration
    By Hair-son in forum Durango Discussions 1998-03
    Last Post: 06-25-2009, 11:35 AM
  2. Vibration
    By makthenif in forum Durango Discussions 1998-03
    Last Post: 12-20-2007, 05:40 PM
  3. vibration
    By buckeye in forum Durango Discussions 2004-09
    Last Post: 11-16-2007, 06:52 PM
  4. To change or not to change the tranny fluid?
    By viperbob in forum Durango Discussions 1998-03
    Last Post: 11-22-2006, 11:43 AM
  5. Bad driveline vibration
    By firecadet613 in forum Durango Discussions 1998-03
    Last Post: 06-07-2006, 05:42 PM
Search tags for this page
1998 dodge durango steering vibration
dodge ram vibrates after brake change
vib after rotor changed
why are my front brakes vibrating on my 1998 durango
whyaremy front breaks vibrating on my 06 dodge ram
