Turn Signal Issue
Results 1 to 8 of 8
Thread: Turn Signal Issue
    Durango Expert JoMc67's Avatar
    Apr 2006
    Virginia
    646
    1099
    Turn Signal Issue
    For the past several months my driver's turn signals have been flashing quickly. I had this issue a couple of years ago and it turned out to be a burnt out bulb, but I don't think that's the problem this time. I tried replacing the taillight socket (swapped them from left to right taillights) and used different bulbs, but all to no avail.
    Any help will be appreciated.
    Thanx, Joe
    Super Moderator tomk's Avatar
    Jun 2004
    Amherst, MA
    10,668
    16
    925 times
    Are all the bulbs flashing? Even when the parking lights are on?
    Be amazed at the friends
    You have here on your trip
    07 JGC Red Rock Limited 5.7L
    And some past Durangos
    de W1PF
    May 2004
    ICE COLD NORTH JOISEY
    27,933
    7
    1747 times
    2013 R/T D HEMI
    I still think one of the sockets is the problem.
    I know this will sound weird, but try turning the sockets ever so slightly in the blinker assemblies. I've seen this cause your problem due to aftermarket fixtures not being made exactly right.
    Durango Jedi Master
    Jun 2004
    Fontana, CA
    7,490
    12
    193 times
    The contact pads where the sockets connect to the housings are really critical and have caused problems in the past. Try turning the parking lamps on and then walking completely around the D to make sure all the lamps are lit evenly. Then turn on the turn signal and do the same thing. You'll probably see a difference and that'll be the bad unit.
    Apr 2006
    Virginia
    646
    1099
    Thanx for the info guys!
    I put the stock taillights back on after I sold the aftermarket ones.
    So, when I turned on all the lights and walked around the D, I noticed the driver's upper taillight bulb is out (as well as the bottom blinker flashing quickly when engaged.) I did play around with moving the sockets ever so slightly, but still have the same problem.
    Do you think it's the taillight socket (upper or lower) that's bad and not any part of the harness attached at the bottom?
    Current: Intense Performance Air-Intake, HO Cams & Intake, Fastman TB, 180 Tstat, 3.92 Gears, PT4x4, Superchips, LPW Diff Cover & Mag-Hytec Tranny Pan, Hotchkis Sways.
  7. #6
    Jun 2004
    Amherst, MA
    10,668
    16
    925 times
    Replace the bulb first. That's easy, cheap, and bizarre things happen when half of a burnt-out filament falls into contact with the other filament in the bulb.
    ?tom
    de W1PF
  8. #7
    Apr 2006
    Virginia
    646
    1099
    Yeah, I did try a few bulbs (used but working) and even moved the bulbs from one socket to the next. Guess I'll buy a new 3157 bulb and see what happens.
    I'll keep you posted.
  9. #8
    Aug 2005
    Antarctica
    15,068
    807
    101 times
    Flex the socket to allow for better/tighter contact on the bulb that appears to be causing the issue.
  1. Driver Turn Signal
    Last Post: 07-13-2010, 06:01 PM
  2. Turn signal problem
    By IndyDurango in forum Durango Discussions 1998-03
    Last Post: 06-03-2010, 06:31 AM
  3. Right Turn Signal
    By Machine in forum Durango Discussions 1998-03
    Last Post: 07-20-2008, 12:24 AM
  4. Right Turn Signal Stays ON
    By Djaizspecial in forum Durango Discussions 1998-03
    Last Post: 02-09-2006, 01:32 PM
  5. Fast Turn Signal
    By EyeSpy in forum Durango Discussions 1998-03
    Last Post: 11-01-2005, 10:41 AM
Search tags for this page
dodge durango forums bad turn signal
