Oil pan removal
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Oil pan removal
    Durango Expert 20durango03's Avatar
    Sep 2008
    Denver, Colorado
    539
    1742
    2002 Durango SLT 4.7
    CAI. H/O Cams. HID 6K. Led Tail Lights. After Market Head Lights. Electric Fan Setup.
    Oil pan removal
    Looking to remove the oil pan from 4.7 in the Durango and here's what I've found so far and would like some info on if this is the easiest way to do this or not.
    Jack up the front of the Durango and install a jack stand.
    Block the rear wheels.
    Remove the oil plug and let the oil drain into a pan being sure to remove as much of the old oil as possible.
    Loosen the bolts holding the oil pan with a socket wrench and remove them with your fingers.
    Remove the oil filter, starter motor, cooler lines, oil level sensor, heated oxygen sensor connector, exhaust y-pipe and then take off the oil pan.
    Scrape off the old gasket with a thin putty knife being very careful not to scrape the surface.
    Make sure all of the old gasket is removed, wipe the surface with solvent, and then spread a bit of oil on it to promote adhesion and apply the new gasket.
    Replace the oil pan, exhaust y-pipe, heated oxygen sensor connector, oil level sensor, cooler lines, starter motor, and install a new oil filter.
    Raise the vehicle slightly with the jack, slide out the jack stand, and lower the vehicle and remove the jacks.
    Fill the engine with the appropriate amount of oil and check the level with the dipstick to be sure you have the right amount.
    2002 Dodge Durango SLT+ 4X4 V8 4.7 144K
    LED Taillights + 3rd. Hids 6000K, Aftermarket Head Lights, H/O Cams. CAI. 180 T-Stat. Mark 8 Electric Fan.
    2000 Dodge Durango SLT+ 4X4 V8 5.9 135K
    Fastman TB 52 MM. CAI. LED Taillights + 3rd. Aftermarket Headers. HID Headlights.
    Super Moderator tomk's Avatar
    Jun 2004
    Amherst, MA
    10,581
    16
    897 times
    4x4?
    What?
    07 JGC Red Rock Limited 5.7L
    And some past Durangos
    de W1PF
    Sep 2008
    Denver, Colorado
    539
    1742
    Yes it's 4x4
  4. #4
    Administrator skitzo.d's Avatar
    Jul 2004
    Northern GA
    5,591
    46
    113 times
    2004 Ram 2500 4x4 Quad Cab and '42 Dodge Dually
    It seems to me you have to take a cross member off under the pan, but I'd have to climb under there again. I need to measure for my new drive shaft, so I'll check it out then and let you know.
    Oh wait. I have the 5.9. It should still be the same or close.
  5. #5
    Durango Jedi Master
    Jun 2004
    Fontana, CA
    7,463
    12
    190 times
    IIRC, on the 4x4 I believe you have to get the dreaded engine support bracket out for the engine and the diff comes off.
  6. #6
    Jun 2004
    Amherst, MA
    10,581
    16
    897 times
    FSM seems to say the big adventure on a 4x4 is pulling the front axle out.
    Attached Files Attached Files
    What?
    de W1PF
  7. #7
    Senior Member RennGent's Avatar
    Jun 2011
    Frederick, MD
    457
    2023
    18 times
    2003 SXT Durango 4.7L
    Yes, the 4x4 4.7 has a lot of stuff in the way. There's a crossmember and, as tomk linked, it looks like the axle is in the way too. It certainly doesn't look like a fun job.
    ~Nate
    4.7L, Fastman TB, Airaid CAI, Superchips 91 tune, Borla cat back exhaust, 180 T-stat, 1" drop, Bilstein shocks, Hellwig rear sway, Mag-Hytec trans & rear diff covers, Energy Suspension Polyurethane Bushings.
    4.7 Performance Options. www.fireflycoachworks.com
  8. #8
    May 2004
    ICE COLD NORTH JOISEY
    27,875
    7
    1723 times
    2013 R/T D HEMI
    Not an easy job!
  9. #9
    Durango Jedi
    Mar 2005
    Roanoke, VA
    4,249
    626
    3 times
    a lot of work! don't feel bad, I've got to do the timing chain and tensioners on mine.
    2003 Dodge Durango 4.7 4x4
    2004 Dodge Ram 1500 5.7 Hemi
    2014 Toyota Camry SE
    2000 Buick Century
  10. #10
    Sep 2008
    Denver, Colorado
    539
    1742
    Ok, was just checking to see the condition from the bottom on the motor. If an engine hoist is needed, I'll just put another motor in while I'm at it. lol
  1. Removal of TB, TPS & IAC?
    Last Post: 05-01-2010, 12:46 AM
  2. Logo removal
    By topsportsman in forum Durango Discussions 1998-03
    Last Post: 07-27-2008, 10:44 PM
  3. Pin Stripe Removal
    By Durangutan in forum Durango Discussions 1998-03
    Last Post: 10-12-2007, 12:25 PM
  4. A/C pulley removal
    By PeteL in forum Durango Discussions 1998-03
    Last Post: 07-23-2007, 10:02 AM
  5. Overspray Removal
    Last Post: 11-03-2006, 12:48 AM
Search tags for this page
03 durango oil pan removal
1998 dodge durango oil pan removal
2000 dodge durango oil pan removal
