Fan clutch noise
Results 1 to 3 of 3
Thread: Fan clutch noise
    Dec 2010
    20
    1964
    Fan clutch noise
    I just installed a new fan clutch and for the first 2 miles or so it sounds like the fan is on 100% After that, it acts normally. I've never heard so much fan noise in my life. My old clutch didn't do this. Is it normal?
    Durango Jedi Master
    Jun 2004
    Fontana, CA
    7,463
    12
    190 times
    It sounds like the silicone isn't setting right in your fan clutch and I'd return it. A question, does your fan normally make a lot of noise at startup? If so, and you'd like to eliminate this and increase cooling a little bit, order the fan and fan clutch from TSB 07-07-98 that addressed this issue. It says to use fan 52027709 and fan clutch 52029767AA. These are from the V-10 and the fan has a slightly different pitch for reduced noise and the fan clutch works differently to eliminate the fan roar at startup. It also increases the cooling ability of the system for your engine. Some folks have said they've done this with the stock shroud, there's a different shroud listed for the 4x4 and the 4x2 setups in the TSB. The complete story is in our operational section of Just 'D' FAQ's on the DOC home page (not on the forum's FAQ page.)
    I did this early on for my D as it didn't cool very well and what a difference it made.
    Super Moderator tomk's Avatar
    Jun 2004
    Amherst, MA
    10,581
    16
    897 times
    It may also settle in after a little running
    What?
    07 JGC Red Rock Limited 5.7L
    And some past Durangos
    de W1PF
  1. Can I run W/O the fan clutch on an 01 4.7 D?
    By greendurango in forum Durango Accessories 1998-03
    Last Post: 09-18-2011, 03:35 PM
  2. Bad fan clutch?
    By Tazdevil in forum Durango Discussions 1998-03
    Last Post: 09-04-2007, 01:57 PM
  3. Noise - A/C or Fan Clutch??
    By GreenD in forum Durango Discussions 1998-03
    Last Post: 02-26-2007, 08:02 PM
  4. To Clutch Fan or not to Clutch Fan that is the question!
    By FSTDANGO3 in forum Durango Accessories 1998-03
    Last Post: 10-09-2005, 02:31 PM
  5. Fan Clutch
    By GTOPaul in forum Durango Discussions 1998-03
    Last Post: 02-11-2005, 12:05 AM
Search tags for this page
2004 dodge durango fan clutch noise
2005 durango clutch fan noise
loud fan clutch durango
