Voltage regulator??
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: Voltage regulator??
    Durango Jedi Neil's Avatar
    Jun 2004
    Marlton, NJ
    2,251
    21
    2 times
    Voltage regulator??
    I had to leave town and didn't get a chance to troubleshoot it yet, but I saw the voltage was right at 12 and not charging. It was probably running off just the battery. I restarted it later and the voltage was back to normal, then I restarted it again and it was back to 12. When I get home I'll have the alternator checked. I know the voltage regulation is controlled by the PCM but where's the regulator?
    Durango Jedi Master
    Jun 2004
    Fontana, CA
    7,576
    12
    218 times
    The regulator is actually a part of the PCM. I'd check all the connections to the battery to make sure they're shiny clean and tight. You should also check the grounds and connections to the PDC for the same conditions.
    May 2004
    ICE COLD NORTH JOISEY
    28,050
    7
    1792 times
    2013 R/T D HEMI
    As said above, it's built into PCM.
    My guess will be a bad alternator.
    Aug 2005
    Antarctica
    15,070
    807
    101 times
    +1. Bad/Failing Alternator.
    If it's an original, it's simply due.
    IndyDurango
    Durango Jedi
    Mar 2005
    Roanoke, VA
    4,249
    626
    3 times
    +2 on the bad alternator
    2003 Dodge Durango 4.7 4x4
    2004 Dodge Ram 1500 5.7 Hemi
    2014 Toyota Camry SE
    2000 Buick Century
  7. #6
    Jun 2004
    Marlton, NJ
    2,251
    21
    2 times
    Wasn't the alternator (I thought it was too.) I changed it last weekend and voltage on the dash was good all last weekend and then yesterday the wife tells me the Air Bag, Check Gauges and Check Engine lights came on. I checked and once again the voltage was low. Now what I didn't do last weekend was check the voltage at the battery before I changed the alternator because my Fluke meter was broken. Right now it's 14.3 volts at the battery with it running but the dash and scan gauge show the PCM is only seeing 11.4 volts. The CELs are 743, 7753 and 1765 which are tranny related for open/shorted 12V circuits controlled by the PCM. The dash lights could also be PCM voltage related. My neighbor is a mechanic and thinks it may be the PCM that's bad. A local junkyard has a 99 5.9 PCM for $100 but I couldn't get it today. Hopefully I can Monday and that's the problem. I'll have to figure out what to do if the stock PCM fixes it as my current one is a Mopar Performance PCM.
  8. #7
    Durango Jedi
    Mar 2005
    Roanoke, VA
    4,249
    626
    3 times
    PM'd
    2000 Buick Century
  9. #8
    Sep 2004
    Anaheim, ca
    5,598
    77
    163 times
    Keep us posted. I'm running a Federal PCM right now as my Cali PCM needs to be fixed, it runs for a little bit and then shuts down for minutes or hours. I figured out how to get it running, but have a temp PCM in place until the Cali one is repaired.
    2015 Dart Aero turbo1.4t, GFB DV+ BOV
  10. #9
    Jun 2004
    Marlton, NJ
    2,251
    21
    2 times
    Where can you get it repaired? I know there are merchants that sell "remanufactured" PCMs but I haven't seen (or looked into) anyone that repairs them.
  11. #10
    Durango Jedi
    Mar 2005
    Roanoke, VA
    4,249
    626
    3 times
    Here are some guys that repairs them for anywhere from $200-$300 depending how extensive the damage is.
    http://ecmtogo.com/ECMTips2.htm
    2000 Buick Century
  1. Voltage Regulator? New PCM? I need your advice
    By swingler in forum Durango Discussions 1998-03
    Last Post: 02-28-2009, 03:39 PM
  2. TPS Voltage Mod?
    By butch1581 in forum Durango Accessories 1998-03
    Last Post: 07-28-2006, 12:35 PM
  3. Bad Voltage regulator?
    By highlander in forum Durango Discussions 1998-03
    Last Post: 06-22-2006, 06:32 PM
  4. Battery Voltage drops
    By BigRick01R/T in forum Durango Discussions 1998-03
    Last Post: 12-15-2005, 08:17 AM
  5. TPS over voltage code p0123
    By russel in forum Durango Discussions 1998-03
    Last Post: 04-12-2005, 01:02 PM
Search tags for this page
1998 dodge durango voltage regulator
2000 durango voltage regulator
voltage regulator 2000 dodge durango
where is the voltage regulator on a 1999 dodge durango
