99 Durango ABS & brake warning light on
Results 1 to 9 of 9
Thread: 99 Durango ABS & brake warning light on
    Nov 2007
    Rugby, United Kingdom
    21
    1661
    I need some help with a problem I've got with my 99 Durango. I have the ABS and brake warning light on intermittently on the dash. I replaced the ABS sensor on the rear axle and the park brake switch and the lights still come on and stay on. I tried unplugging the electrical plug to the ABS control unit, cleaned the terminals and plugging it back in. I started it up and, after a few seconds, the lights go out and seem to stay out until you turn it off and restart it, then they come back on. I did the start and switch it off test a couple of times, and once the lights went out and stayed out without disconnecting the plug, but then guess what, on starting they came back on and stayed on.
    I also disconnected and reconnected the battery and it made no difference.
    Anyone got any more suggestions as I'm at a loss??
    BTW, I only have RWAL.
    2001 Durango SLT 5.9 2wd
    2000 Dakota R/T
    Durango Jedi Master
    Jun 2004
    Fontana, CA
    7,463
    12
    190 times
    Some basic questions first. What condition are the rear brakes in physically? Have they been adjusted recently? How long since you had the hydraulic fluid flushed in the brake lines? Do you have access to a scanning tool that can read brake DTC's? What's your fluid level in the master cylinder? Don't fill it if it's low!
    Sep 2004
    Anaheim, ca
    5,493
    77
    145 times
    Further diagnostics may lead to changing the ABS control unit. $600 installed from "MY" dealership, which turns out to be more than the other dealership would have charged. It did get rid of my 2 dash lights. Also make sure your power steering fluid isn't leaking as it can cause issues with the electrical systems.
    2015 Dart Aero turbo1.4t, No mods, YET!
  4. #4
    Nov 2007
    21
    1661
    Not sure on condition of rear brakes, previous owner reckons he changed L/H rear wheel cylinder and shoes, guessing not complete set of shoes as 1/2 pair of shoes were left in rear load area!! Would this cause a problem even if I hadn't moved the car and why does it go on and off when it feels like it?
    2000 Dakota R/T
  5. #5
    Durango Jedi Neil's Avatar
    Jun 2004
    Marlton, NJ
    2,251
    21
    2 times
    Rather than throwing any more money at it you need the brake code read so you know what it is. Note: you can't do that with an standard OBD reader nor pull it up in the odometer, you need an ABS code reader. Find a shop that'll just read the code for you and then you can decide if you want to fix it yourself.
  6. #6
    Nov 2007
    21
    1661
    I'll have to try to find someone with an ABS code reader, not sure if any at work will do it as most of ours cover UK market vehicles.
    2000 Dakota R/T
  7. #7
    Durango Jedi Master
    Jun 2004
    Fontana, CA
    7,463
    12
    190 times
    Probably due to fluid contamination. As far as the half set redo, I'd check the brake adjustment in the rear as that controls the pedal height for the D and the self adjusters never work. It's possible that the other side hydraulic cylinder has started to leak or the shoes are worn out on that side. Get a read as suggested and then do a complete physical inspection to learn where the rear brakes are at physically.
  8. #8
    Nov 2016
    1
    19441
    1999 Durango 2wd, 125kmi, i have a noise that is like a vibration coming front the front left, when I stepid on the brakes the stops, could this be my abs, spazing out?
  9. #9
    Super Moderator tomk's Avatar
    Jun 2004
    Amherst, MA
    10,581
    16
    897 times
    Does it happen all the time, even when you are not moving?
    Does the vibration change with speed?
    What?
    07 JGC Red Rock Limited 5.7L
    And some past Durangos
    de W1PF
  1. Brake Warning light
    By beastofwar in forum Durango Discussions 2004-09
    Last Post: 11-24-2010, 11:26 PM
  2. ABS light + Brake light = $1,600? (kinda LONG)
    By cjarnesen in forum Durango Discussions 1998-03
    Last Post: 10-25-2010, 08:17 AM
  3. 01 D 3rd brake light
    By greendurango in forum For Sale
    Last Post: 03-15-2010, 07:37 PM
  4. Brake / ABS warning light stays on
    By BlackD_NC in forum Durango Discussions 1998-03
    Last Post: 06-15-2005, 09:23 PM
  5. Airbag Warning Light
    By cracker in forum Durango Discussions 2004-09
    Last Post: 04-26-2005, 09:05 PM
Search tags for this page
1999 dodge durango abs and brake light on
2001 durango abs and brake light on
99 durango abs and brake light on
99 durango rwal brake light and abs light troubleshooting
