Replacing Central timer Module ('01 4.7)
Results 1 to 8 of 8
Thread: Replacing Central timer Module ('01 4.7)
    Junior Member jjohn87's Avatar
    Jan 2006
    Des Moines, IA
    116
    985
    Ok, I've been putting off replacing this thing for about three years and I think it's time to finally bite the bullet and get it done. If I were to order the part and replace it myself, would it start and allow me to drive it to the dealer to reprogram the keys?
    Also, in speaking with the parts dept at the local stealer, they mentioned that they'd need the VIN and mileage and have the part programmed and ordered from Chrysler. That doesn't seem quite right.
    As always, thanks for any assistance
    Yeah, I'm a member
    2001 SLT+ 4.7 Silver (Mine)
    2006 SLT AWD HEMI Red (Wife's)
    May 2004
    ICE COLD NORTH JOISEY
    28,050
    7
    1792 times
    2013 R/T D HEMI
    It most likely won't if your D has security.
    About $400 complete at the dealer.
    Super Moderator tomk's Avatar
    Jun 2004
    Amherst, MA
    10,937
    16
    1016 times
    They may well need the VIN to get the right configuration.
    Then again, some places won't sell you a lug nut without a VIN.
    What?
    07 JGC Red Rock Limited 5.7L
    And some past Durangos
    de W1PF
    Durango Jedi
    Mar 2005
    Roanoke, VA
    4,249
    626
    3 times
    I had to replace mine on my 01. Just give them your VIN# so they order the right one. There are 2 versions of the CTM, a loaded one and a base one Mine was pretty much plug-n-play and very very easy to install! The only thing that won't work is your key fobs. Take them to the dealer to get them programmed in about 20-40 depending on dealer. If you install it yourself, it's located on the drivers side kick panel and you have to remove the plate along the edge of the door to gain access to the screw holding on the kick panel cover. There's also one up top hidden by the carpet once the panel is removed and 3-4 long screws holding it in. Remove those and it'll come loose and then there are some connectors at the top of the CTM. Be careful with unplugging those. Installation is just reverse this procedure! Good luck and PM me if you need any assistance! Jim
    2003 Dodge Durango 4.7 4x4
    2004 Dodge Ram 1500 5.7 Hemi
    2014 Toyota Camry SE
    2000 Buick Century
    Senior Member GolsonMolson's Avatar
    Aug 2009
    Port Elgin, Ontario
    447
    1832
    2 times
    Mine was plug and play as well.
    Got it used from a local wrecker last fall and have had no problems. I had to give the VIN# to the wrecker so he could cross check something for some reason! My year had a recall though and maybe that was why.
    The bonus was I only paid $100 for it.
  7. #6
    Durango Guru Don Fox's Avatar
    Sep 2004
    Oxford, Ohio
    1,257
    100
    51 times
    When the CTM on my 01 went, the bill was around $475 out the door. Seems like I recall another poster on another forum that I assisted with info and she ended up paying $525 for hers installed.
    As Indy pointed out at that time, they were charging more than book time and it was a full hour instead of the half or third it should have been. In my case, I didn't make waves since they've treated me very well on both my D and the wife's Grand Caravan.
  8. #7
    Aug 2009
    Port Elgin, Ontario
    447
    1832
    2 times
    I forgot to point out, I had to get the fobs reprogrammed after I replaced mine. They charged me $25.
  9. #8
    Jan 2006
    Des Moines, IA
    116
    985
    Thanks everyone!
    Yeah, I'm a member
  1. Central Timing Module?
    By midnite in forum Want To Buy
    Last Post: 07-02-2012, 03:24 AM
  2. **SOLD** Central Timer Module for 01 D
    By greendurango in forum For Sale
    Last Post: 03-14-2010, 07:02 PM
  3. central cap :(
    By Coolguy in forum Wind Tunnel
    Last Post: 07-23-2006, 08:52 AM
  4. Central Timer Module=Body Control Module=Time&Alarm Module
    By MAD RT in forum Durango Discussions 1998-03
    Last Post: 12-25-2005, 03:34 PM
  5. central timer module recall
    By DriftyDurango in forum Durango Recalls/TSB's 1998-03
    Last Post: 06-15-2005, 09:52 PM
Search tags for this page
01 dakota central timer module
01 durango central timer module
2001 dakota central timer module
2001 dodge dakota central timer module
