Tranny going to neutral when kickin in passing gear.
Results 1 to 6 of 6
Thread: Tranny going to neutral when kickin in passing gear.
    Sep 2008
    3
    1738
    What causes it to go into neutral when you kick it? If I ease down on the gas pedal, it goes down one gear (or the clutch unlocks, not sure on this) but if I push down a little further, it goes to neutral and engine revs but there's no power to the drivetrain. What's the sequence for shifting as far as when the torque converter locks up? It's a 4 speed tranny but the RPMs drop 4 times, like it was a 5 speed.
    Bigdave13@msn.com
    Dave
    '99 D, stock, 4wd, 318, 220,000+ miles, tranny rebuilt twice
    May 2004
    ICE COLD NORTH JOISEY
    27,875
    7
    1723 times
    2013 R/T D HEMI
    Sounds like you have a Governor Pressure Solenoid problem or an improperly adjusted TV cable.
    When's last time the tranny was serviced and were the bands adjusted?
    Super Moderator tomk's Avatar
    Jun 2004
    Amherst, MA
    10,581
    16
    897 times
    Re: tranny going to neutral when kickin in passing gear
    Quote Originally Posted by BigDave13
    It's a 4 speed tranny but the rpms drop 4 times, like it was a 5 speed.
    Bigdave13@msn.com
    4 gears plus converter lockup
    What?
    07 JGC Red Rock Limited 5.7L
    And some past Durangos
    de W1PF
  4. #4
    Sep 2008
    3
    1738
    Quote Originally Posted by tomk
    Bigdave13@msn.com
    Right. What I was asking is, when exactly does the converter lock. After a certain speed is reached? When it shifts into 3rd? Or after it goes into O/D?
    Quote Originally Posted by FSTDANGO3
    It was rebuilt 20k miles back. Mopar fluid and the bands were adjusted. Is the Governor Pressure Solenoid one of the ones on the valve body?
    Dave
  5. #5
    Jun 2004
    Amherst, MA
    10,581
    16
    897 times
    Converter lockup is controlled by the PCM based on throttle, roadspeed, etc, and is available in 3rd and 4th gear.
    Do you get the RPM flare when doing a kickdown with O/D off? When you do a manual D->2 downshift?
    ?tom
    What?
    de W1PF
  6. #6
    Durango Jedi Master
    Jun 2004
    Fontana, CA
    7,463
    12
    190 times
    Yes, the solenoids are on the valve body.
  1. Tranny hanging in passing gear too long
    By shadango in forum Durango Discussions 1998-03
    Last Post: 03-22-2012, 05:58 PM
  2. 2003 Tranny won't stay in top gear while towing
    By Tedd R in forum Durango Discussions 1998-03
    Last Post: 07-14-2009, 01:01 PM
  3. No 2nd gear/ tranny questions
    By 71455olds in forum Durango Discussions 1998-03
    Last Post: 11-24-2008, 11:36 AM
  4. Passing gear kick down
    By Tino in forum Durango Discussions 1998-03
    Last Post: 07-20-2007, 06:07 AM
  5. Passing gear cable
    By snowskull in forum Durango Discussions 1998-03
    Last Post: 07-12-2007, 04:45 PM
Search tags for this page
03 dodge durango goes to neutral in third
tranny shifts from 4th to neutral instead of passing gear
