Transfer case control module question on 01 D
Results 1 to 4 of 4
Thread: Transfer case control module question on 01 D
    Durango Jedi
    Mar 2005
    Roanoke, VA
    4,249
    626
    3 times
    On my 01 my transfer case shift indicator lights aren't working. It's supposed to have little lights that illuminate when you turn it from 4HI to 4LOW to 2WD so I guess my 4wd isn't working as well. Does this go out pretty easy? I checked all the fuses and they were good? Could the TCCM be the culprit? Where's it located?
    2003 Dodge Durango 4.7 4x4
    2004 Dodge Ram 1500 5.7 Hemi
    2014 Toyota Camry SE
    2000 Buick Century
    Durango Jedi
    Mar 2005
    Roanoke, VA
    4,249
    626
    3 times
    I'm going to replace the CTM to see if that helps, the dealer said it controls some of the power to the TCCM so hopefully that'll solve it. I got a used one from a junkyard the dome light problem was solved but the remotes wouldn't program and the 4x4 switch still doesn't light. The old CTM and the junkyard one both had a code that their DRBII scan tool read as something on the order of "failure of the CTM" so I guess I'll have to order a new one; it runs $218 from the dealer. Get this, the part # has changed 5 times! The old part # was 56045453AF and the new part # 5114191AA retails for like $297 so they're giving we a little break on it. Does anyone know the part # for the TCCM in case I have to order one of those? They checked the transfer case module system using their scan tool and it read "no responce" so I guess I'll have to wait and see.
    TO BE CONTINUED?
    2000 Buick Century
    Durango Expert JoMc67's Avatar
    Apr 2006
    Virginia
    646
    1099
    Green,
    Not sure if this applies to you, but I had a recall on my 01' TC Module which was either re-programmed or replaced (can't remember which) years ago.
    Joe
    Super Moderator tomk's Avatar
    Jun 2004
    Amherst, MA
    10,863
    16
    992 times
    TCCM is somewhere near the steering column, as far as I can tell.
    Attached Thumbnails Attached Thumbnails Transfer case control module question on 01 D-01_tccm.jpg
    Be amazed at the friends
    You have here on your trip
    07 JGC Red Rock Limited 5.7L
    And some past Durangos
    de W1PF
  1. Replies: 6
    Last Post: 03-03-2016, 06:38 AM
  2. Transfer Case Control Module Question
    By chrisscerbo in forum Durango Discussions 1998-03
    Last Post: 11-20-2012, 12:47 PM
  3. Transfer case question
    By TheDodgeGuy in forum Durango Discussions 1998-03
    Last Post: 03-21-2012, 05:41 PM
  4. **SOLD** Transfer Case control module for 01 D
    By greendurango in forum For Sale
    Last Post: 03-14-2010, 07:26 PM
  5. Central Timer Module=Body Control Module=Time&Alarm Module
    By MAD RT in forum Durango Discussions 1998-03
    Last Post: 12-25-2005, 03:34 PM
Search tags for this page
2001 dodge dakota transfer case control module
2001 dodge durango transfer case control module for sale
2001 dodge durango transfer case module
dodge dakota tccm location
dodge durango 2001 timer and alarm 5114191aa
