Torsion Bar question
Results 1 to 8 of 8
Thread: Torsion Bar question
    Oct 2005
    Southern NJ
    16
    865
    An many of you know, I cranked up my torsion bars 6 turns on each side last week and had new tires installed with an alignment. While putting up Christmas decorations I was looking at my truck from the front and something didn't look right so I broke out the tape measure and found the right (passenger side) front is 1/2" lower than the left when measuring at the lip of the wheel well. I also checked the running boards and the same is true and the left front tire sticks out of the fender well by about 1/4" while the right one is 1/2" short of the edge of the fender well.
    Should I crank the right side up 2 more turns for another 1/2" then have it re-aligned?
    '05 Durango SLT Bright White 5.7 Hemi
    33" Cooper SST Mud Terrain
    K&N Filter
    Air Lift Rear Suspension
    Administrator skitzo.d's Avatar
    Jul 2004
    Northern GA
    5,589
    46
    112 times
    2004 Ram 2500 4x4 Quad Cab and '42 Dodge Dually
    Kick the low side up a 1/4", take it for a ride and recheck. Raise as needed. I'd drive it around so the suspension chances settles in and make sure it's on something level ground when measuring.
    Grasshopper Endi.Rage's Avatar
    Jun 2012
    Goldsboro, NC
    91
    2110
    Agreed. When I did mine, I had to drive it around and hit a few bumps. Then I pulled it in the garage, measured, and adjusted accordingly. It took a few tried before I liked the way it looked (I'm OCD about that kind of stuff. LOL)
    1999 Dodge Durango SLT 4x4 - Platinum
    Lots of upgrade goodies
  4. #4
    Oct 2005
    Southern NJ
    16
    865
    I have a little OCD in me too, that's how I noticed it! Thanks for the input, will go for it.
    K&N Filter
  5. #5
    Durango Expert DelDurango's Avatar
    Oct 2004
    Thornton, CO
    777
    321
    5 times
    99 Chilil Pepper Red Durango, tan leather interior
    Mopar Performance intake, PPH Headers/custom exhaust, Superchips, MSD coil, helixed TB spacer
    When replacing torsion bars I'm guessing it'd be a good idea to count the number of turns when removing the old ones and install the new ones to that number of turns?? I had a little oops on a trail run and part of the carnage has a bent torsion bar. I'm hoping to replace it and the upper control arm before I have shoulder surgery on Jan 7th. Otherwise it'll be Spring/Summer before I can get to it and I don't like the idea of my passenger front tire being an inch closer to the rear than the drivers front tire.
    Dan - retired military, got my AA from Front Range Community College, Westminster, CO. Now at CU Boulder
    99 D 4x4 5.9 / 4 spd a/t, CPR, leather interior, MSD #8228 coil, homemade CAI,Superchips 3715, (PPH headers/full custom dual exhaust, helixed TB spacer, Mopar M1 intake to come).
    97 JGC Limited 5.2/4 spd a/t, f/t 4wd, red, leather interior, mods to come
    04 Yamaha V Star 1100
  6. #6
    Jul 2004
    Northern GA
    5,589
    46
    112 times
    It doesn't matter how many turns. However, replacing just the one will give you 1 new one and 1 old one; maybe you should replace them both? Either way, good level ground and careful measurements will get you level in the end.
  7. #7
    Jul 2007
    Real close to Muffler Man
    4,305
    1532
    578 times
    2007 Durango Night Runner
    1 of 241 made
    I don't mean to be Captain Obvious here, but I'd want to get that thing leveled out ASAP. Seems to me that a tilted truck is a bad thing for performance, re staying upright.
    2007 HEMI Nightrunner D
    2015 Grand Caravan R/T
    1996 Ford E-350
  8. #8
    Oct 2004
    Thornton, CO
    777
    321
    5 times
    Quote Originally Posted by skitzo.d
    Considering my current financial situation, I'm replacing the bent torsion bar with one from a salvage yard. When things improve, I intend to replace both torsion bars and the upper & lower control arms with new parts as well as all the suspension bushings (I want to go with polyurethane.) I even plan to R&R the leaf springs as mine are showing their age.
    Quote Originally Posted by Durangutan
    The torsion bar is only slightly bent, not enough that the truck is leaning or anything like that.
  1. New tires with torsion crank
    By Hemi Durango in forum Durango Accessories 2004-09
    Last Post: 11-10-2014, 11:26 AM
  2. Torsion Bar Adjustment Fiasco
    By Bakstoy in forum Durango Discussions 1998-03
    Last Post: 05-25-2009, 01:56 PM
  3. Torsion bars?
    By DurangoDude in forum Durango Accessories 1998-03
    Last Post: 10-27-2007, 08:47 AM
  4. how many cranks for torsion bar lift
    By paisley_tele in forum Durango Discussions 1998-03
    Last Post: 09-22-2007, 09:28 PM
  5. New shocks for 4X4 D with AAL/torsion lift
    By S-Works in forum Durango Accessories 1998-03
    Last Post: 01-05-2005, 11:26 AM
Search tags for this page
1999 dodge durango torsion bar
1999 dodge durango torsion bar lift
1999 durango 4x4 torsion bars
cranking torision bars 99 durango
torsion bars on a 99 dodge durango
