Upgrading single V6 exhaust to R/T duals with Part Numbers
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 51
Like Tree9Likes
Thread: Upgrading single V6 exhaust to R/T duals with Part Numbers
    Feb 2014
    La Mirada, CA
    81
    3986
    11 times
    2011 Crew 3.6 RWD
    Full Limo Tint, Stock R/T Exhaust
    Well, instead of hijacking everyone else's threads, I figured I'd start my own, that way I can put it all together and in one place. I upgraded my 11 Crew v6 to the factory R/T exhaust and figured I'd put my research findings into one place so anyone else looking to upgrade to duals can find it.
    This is what you are starting with:
    Chrysler Parts Diagram:
    Upgrading single V6 exhaust to R/T duals with Part Numbers-tg11315.jpg
    Actual Item take off the v6:
    Upgrading single V6 exhaust to R/T duals with Part Numbers-v6-exhuast.jpg
    And as you can see here on the R/T Parts diagram, there are a few items that are missing to attach the resonator on the driver side (parts 12, 14, and 15):
    Upgrading single V6 exhaust to R/T duals with Part Numbers-tg11325.jpg
    Parts needed:
    -Dual Exhaust of your choice - I picked the factory R/T exhaust bought second hand that I found here. You could also pick Flowmaster/Magnaflow/Borla/Corsa/etc, and any will fit
    -Driver Side Hanger Bracket (#12 in diagram) - Part# 68056521AC
    -Driver Side Pipe Isolator (rubber bushing, #14 in diagram) - Part# 5103520AA
    -Driver Side Resonator Isolator (rubber bushing, #15 in diagram) - Part# 52128501AA
    -New Lower Bumper Valence (will cover part #s later)
    If you pick the factory R/T exhaust, this is the actual "take-out parts you should get when you pick up the R/T exhaust:
    Upgrading single V6 exhaust to R/T duals with Part Numbers-rt-exhaust-2.jpgUpgrading single V6 exhaust to R/T duals with Part Numbers-rt-exhaust.jpg
    Make sure that if you are installing or having someone install, that the extension pipe from the v6 exhaust is used to attach the passenger cat-pipe to the muffler. The one from the dual v8 setup won't work. Also, for reference, the v8 exhaust will fit in the back of a Durango with the rear shut, but the front passenger seat will need to fold flat (sorry Citadel owners, you might run into issues transporting)
    Now for the confusing part, the rear bumper lower valence. There are 8 different part numbers, and this piece gave me the most frustration in my search, since not all sites listed the differences between them and others used a 3 digit "sales code" that is known to Chrysler P&A people but not general public. I had to call many different dealership before I found one in Dallas that would help me out (keep in mind I'm in California)
    Which one do you pick? Depends on options and desired look. There are 3 different "option choices" that make the different part numbers:
    -With or Without Dual Exhaust
    -With or Without Accent Color
    -With or Without Tow Package
    Since 4 of the 8 part numbers are for the single exhaust setup, I will exclude them, otherwise you wouldn't be reading this
    Remaining part numbers: ***Note, these are for the 11-13 MY, the 14+ has a different valence***
    68092112AA - With Accent Color/Without Tow Package
    68092115AA - Without Accent Color/Without Tow Package
    68092113AA - With Accent Color/With Tow Package
    68092116AA - Without Accent Color/With Tow Package
    Tow package is pretty self explanatory, so if you have one, pick the 68092113AA or 68092116AA. If you don't have a tow package, pick 68092112AA or 68092115AA
    This next part was the hardest for me to get info on: What does "With Accent Color" and "Without Accent Color" mean. This is where that Dallas dealer was very helpful.
    Does your Durango have/want the textured black pieces on the bottom all the way around like this?
    Then you want to get "With Accent Color"
    Do you have/want smooth, painted pieces all the way around the bottom (I believe only R/T, Heat, and Rally-e) like this?
    Upgrading single V6 exhaust to R/T duals with Part Numbers-dodge-durango-heat-1297291661.jpg
    Then you want to get "Without Accent Color"
    For mine, I used 68092112AA because I wanted to keep the black around the bottom and I don't have a tow package (will add later), and combined with the R/T exhaust, here is before and after:
    And since I love the sound, here are a couple sound clips I took:
    Start/idle/rev/launch
    Light Throttle Drive-by
    ****UPDATE****
    Took a vid today merging onto the freeway so everyone can hear the "popping" sound during hard acceleration upshifts. I have only heard it on 1-2 shifts, but never accelerated that hard for 2-3 or other shifts
    Last edited by imadude1134; 08-05-2015 at 09:58 AM. Reason: added pics... added a new vid... fixed some wording
    Dec 2014
    Texas (DFW area)
    83
    8351
    9 times
    2015 Bright White R/T
    Volant CAI, BT Catch Can, Husky Mud guards, Factory hitch
    Nice job! The rear end looks so much better with duals, imo.
    Senior Member
    Sep 2014
    Olathe, KS
    295
    7222
    56 times
    2014 Durango Limited
    Great job. They should all have duals. I mean -- even the Explorer does. It's tough to find something in this class that doesn't.
    '14 Limited AWD in Granite: Premium Group, 2nd Row Captain Chairs, 2nd Row premium console, Steelcraft running boards, 20% front tint, cargo cover, Mopar slush mats, Airaid QuickFit air intake, Alpine aftermarket center channel speaker.
  4. #4
    Senior Member fat tony's Avatar
    Jun 2014
    SF BAY AREA, CA
    343
    5682
    73 times
    2014 Dodge Durango Rallye
    Mopar CAI, UPR Oil Catch Can, Magnaflow Exhaust, Mopar Pedal Kit, Mopar all weather floor mats
    I wonder if the 2014 rallye has the same exhaust or something similar. I know its a performance exhaust but does it sound like that when you rev?
  5. #5
    Feb 2014
    La Mirada, CA
    81
    3986
    11 times
    2011 Crew 3.6 RWD
    Quote Originally Posted by fat tony View Post
    I believe Heat and Rally-e just use the standard v8 exhaust from Limited/Crew/Citadel to account for the extra hp, because they don't have any different sound from the standard v6. Also, all the literature I read just says "dual exhaust" or "dual exhaust tips" and doesn't mention performance exhaust or anything. R/T literature does mention an R/T specific exhaust, but doesn't call it performance, only "tuned"
  6. #6
    Senior Member kpeterha's Avatar
    Dec 2012
    San Diego, CA
    355
    2137
    79 times
    2011 Durango R/T
    Tim, you did a great job. It looks and sound fantastic. Happy New Year! Karen.
    imadude1134 likes this.
    2011 R/T RWD - Redline Red - 20X9 +34 Gloss Black SRT "Spider Monkey" Reps - MGP Caliper Covers - Gorilla Lug Nuts - Bwoody front and rear sway bar end links - Bwoody rear upper control arms - Grocery Getter Strut Tower Brace - Fastman 85mm throttle body - aFe CAI - Corsa Performance exhaust - custom 91 octane tune - BT catch can
  7. #7
    Durango Expert RangoLimited's Avatar
    Aug 2014
    Western Massachusetts
    957
    6919
    219 times
    '15 Dodge Durango RT
    20" SRT rep rims, WeatherTech deflectors, front tints, much more coming soon
    Nice! I'd like to do the rt exhaust as well but I also want to install the Mufflex resonator delete kit (below). I think it will improve the sound even more.
    5.7 V8 Hemi Rear Muffler Bypass - Mufflex Performance Store
    2015 Durango RT true blue (mine)
    2015 Sienna XLE premium (hers)
    2014 Durango limited awd (gone)
  8. #8
    May 2004
    ICE COLD NORTH JOISEY
    27,872
    7
    1723 times
    2013 R/T D HEMI
    Actually with the V6 Using just the R/T exhaust will sound good, Using the Mufflex as well, maybe not so good and no backpressure and less TQ.
  9. #9
    Feb 2014
    La Mirada, CA
    81
    3986
    11 times
    2011 Crew 3.6 RWD
    Yea, I would think so. Also, the lack of back pressure from a resonator delete kit might make it sound farty and like an import
  10. #10
    Senior Member
    Sep 2014
    Olathe, KS
    295
    7222
    56 times
    Even the R/T exhaust on the V6 sounds a little raspy for my taste. I'm used to the deeper sound of Magnaflows. The Mufflex delete may cause a lot of drone on the highway. There's also very little details on that kit. I assume it deletes both rear mufflers/resonators?
  1. How do I OEM part numbers?
    By qzyv1r in forum Durango Discussions 2011-13
    Last Post: 05-09-2014, 12:32 PM
  2. Mopar Part Numbers
    By k2epm in forum Durango Discussions 1998-03
    Last Post: 07-06-2006, 08:50 AM
  3. I need the part numbers for?
    By RT Mark in forum Durango Discussions 1998-03
    Last Post: 01-27-2006, 11:03 AM
  4. Magnaflow part numbers
    By Radio Flyer in forum Durango Discussions 1998-03
    Last Post: 04-18-2005, 04:02 PM
  5. OEM part numbers (brake pts) Please help
    Last Post: 02-02-2005, 12:18 PM
Search tags for this page
2015 durango rear dual exhaust bumper
2016 dodge durango exhaust diagram
dodge durango 2015 exhaust diagram
durango crew v6
will durango rt exhaust fit on non rt images
